95 firebird formula 350 lt1 no ac
Have a 95 formula lt1 m6 that has a lt4 hotcam and loss air out the vents. It has defaulted to defrost from what ive been reading. The air pump also has been deleted as well. Any one know where the vacuum lines run to and from for the chwck valve that is right next to the pcm?https://uploads.tapatalk-cdn.com/201...da6e3ca127.jpg
Sent from my SAMSUNG-SM-G930A using Tapatalk
The easiest thing to do to restore air to your vents is to run a new vacuum line to the t-fitting near the pcm. If you take out the glove box you should be able to find the black hose going to the hvac controls. That is the vacuum line. You can run the new line through the wire harness grommet on the passenger side under the pcm. It takes no time to do and is very cheap or free if you have some line laying around.
