No shortage of threads from a variety of sites on this topic but I'm still unsure on a couple of things.
If it is pertinent, this is for 96 Z28 OBDll.
From what I can gather;
the LT1 crank snout has a keyway but the factory hub isn't keyed. An after market Hub/damper (ATI etc) is likely to also have a keyway slot, will not come with the application specific key but I can likely get an appropriate one from my local Napa or similar.
indexing the damper to the hub is unnecessary as the holes in the damper are arranged in such a way as to make it impossible to bolt them together in anything but the correct orientation. If this is the case then If I can get the appropriate key, once assembled the timing marks on the after market damper should be correctly oriented? On my old SBC I would get the engine to TDC 1 before doing alot of things. Seems unnecessary for the LT1?
If I decide to reuse the old factory damper and I remove the factory hub how can I be sure that I put it back on in exactly the same spot short of scribing and index mark on both hub and crank snout? Does it matter?
I currently have the stock damper off, stock hub still in place a nice shiny looking keyed hub (ASP?) in a box and access to the correct ATI damper/Hub assembly NIB really cheap from someone who sold his car.
Kind of a lot of questions. Thanks for your patience!
Jon
