Does anyone have a set of coil brackets to mount ls style coils on the centerbolt valve covers ? Anywhere besides Efi connection make them ?
http://uploads.tapatalk-cdn.com/2016...27f81fc312.jpg
I've got these. Bought them for a 24x setup and went another direction. One set is for the heat sink coils and the other is not. I think the aluminum ones are for non heat sink
BP automotive makes a nice economical set. And he is a sponsor on here also.
I have a set of coils with the heat sink already. The black setup looks like the factory bracket from the ls motor which won't clear the oil cap or breather on lt1. Which coil is the aluminum set for and what are you asking for them ?
The 2 on the right are factory ls brackets. The single one pictured is a modified factory bracket that was on an lt1. I've got the other one somewhere. I'll have to see what the aluminum ones fit. I was thinking they were the opposite of the modified set. I'll get back to you
http://uploads.tapatalk-cdn.com/2016...a9e82c2a8d.jpg
The aluminum brackets are for the heat sink coils and attach to the fuel rails. $50 shipped
Same hardware that holds the injector rails down. I don't think there will be anything there to bolt to on a single plane though. Most of the rails for single plane intakes bolt through the side of the rail. This would be more for factory intakes. I could probably make you a set that would work if you didn't want to bolt to the valve cover.
If he doesn't take it, I'll take it @firebird_1995
