I have 94 z28,I need the bracket that holds the metal pipes.1 going into the regulator 1 into the fuel rail.The fuel lines connect to 2 metal pipes.there is a bracket that holds them metal lines.Thats waht I need.
I'll see if I can find one in the spares bin. If so, just cover the ride and it's yours.
I wont it thanks for helping
Is this the bracket? Attachment 36792
Sent from my SCH-I605 using Tapatalk
Thats what it looks like.There a top to it and a bolt that goes threw both.Do you have the top and maybe the pipes for it?
I have the small pipe that goes into the fpr. I don't think I have an extra fpr bracket that slides over the fuel rail with an extension for holding the fuel lines.
Look at the Shoebox photo I posted in your thread about the leaking FPR. That shows the bracket. I think only the short return pipe that pushes into the FPR is replaceable. The supply pipe is firmly attached to the passenger side rail. I think we had to cut the end of the rail off to remove it, so we could weld on a -6AN fitting. Since I no longer use the stock fuel lines, the stock FPR, or the bracket you are looking for, I will see if I still have the fuel line bracket in the box of surplus parts from 16 years ago. I know I sold the FPR, so not sure about the bracket.
Im not sure really Injuneer.But I do need the 1 pipe that goes into the FPR and the bracket that holds them both.If I can come up with them 2 parts.I will have my car going.Thats all I like being done.
I haven't sent any parts yet. Just got back from Vegas.
