Water pump or thermostat?
One of these two parts has recently failed on my car. A couple weeks ago, as I was leaving a restaurant, I noticed a big puddle of liquid under my car. I smelled it and confirmed it was coolant. I wasn't able to figure out where it came from, but the level in my car was a little low. I didn't have time to mess with it, so it got parked. The coolant temperature was a little higher than normal, but not high enough to be concerned.
Yesterday I decided to do done troubleshooting on my supposed coolant leak. I noticed the temp gauge on the dash was rising unusually fast and the fans weren't coming on, so I turned the car off and plugged in my laptop. The engine temperature was around 150. After a couple cycles of running and stopping the car (I didn't let the gauge get much more than 3/4) the temperature became high enough for the fans to come on. I also tried manually running the fans, but the temperatures rose the same add without the fans. I also turned the heater on full blast, but only got cold air and the radiator was still cold too.
I forgot to add, all this was after I refilled the cooling system to the proper level. I could see the radiator never getting warm with a stuck thermostat, but what about the heater core? Is that a sign that the pump is dead? I might just replace both anyway since the pump is 21 years old with 150k...
Sent from my SM-N920T using Tapatalk
