6 Attachment(s)
quarter panel replacement
Well i finally took this on. It wasn't as bad as i had thought, but it was still pretty time consuming. im about ten hours deep at this point.
I couldnt really find any info online on how to even begin this project so i took some pics along the way. Maybe it will help someone in the future.
I drilled the spot welds out on the replacement fender. I should have picked up a spot welding bit, but i just used a step bit. It worked well, but made the holes way too large in most places. the smaller the hole you drill, the easier it will be to fill in when welding later.
The spot welds are pretty tough to find, if you sand the paint off but dont go too deep, you can see the low spots where the spot welds are.
After i removed the replacement panel, i got to thinking...if i drill my car like this, it will be hell to fill in the holes in the body itself.
So this parts very important,
when removing the throw away quarter panel, grind the spot welds off. So that the car itself is unharmed, and you are only destroying the first layer of metal.
There are a lot of spot welds to find. There are about 20 in the door jam, along with a couple of welds at the edges there. Then there are about 30 on the fender lip. i cut the fender lip out. there are about another 30 inside the trunk on the backside of the fender. Not looking straight down, but looking back at the fender. I first started drilling the wrong ones here. There are also three spot welds at the back right above the tail light. and three or four more towards the bottom at the very back. Then they just follow the bottom of the fender. I cut a straight line here, and welded it back. seemed easier to me.
I also cut it just below the roof. the roof is fiberglass, and i dont know what the protocol for getting in behind there is, but when i tried to peel it back on my junk car it started breaking. so i cut about an inch below the fiberglass on the line, and welded it back there.
If you have never tried to match metal up like this before, it can be tough. I'm no expert by any means, i dont even measure it. I just got it close, then hung the fender. I then used a marker to mark how much more i need to take off and cut a little less. It took a few tries but this is the best way i have found. I am definety not a body man though. lol
I'll probably think of more tips and steps later but heres a start!
