Downsizing my never used meth setup, and selling off my huge flow stuff.
http://www.alcohol-injection.com/en/...zles-do14.html
$15, never had meth or anything through it. Just been fastened to my intake.
hmmm... what else would i need for this to work? the eaton in the Audi could use some meth in the summer.
At minimum; pump, tank, and line.
We got a spare anco washer pump and tank. I'm kinda new to the meth injection stuff and the info on scaudi is very lacking. I have a good place to tap the intake elbow after the maf and iat. Does the ecm need tuning? The heatsoak on this m62 setup is pretty bad. We are rebuilding the blower next week. The rear needle bearings are rumbling. Is this something you set up with a wot switch like nitrous? Soory for the noobish questions, but I am noobish to this.
If/when my setup comes on, its set for some boost point via the boost controller. So say 4psi and it triggers the pump relay to kick on. (alternatively you can buy solenoids so you run the pump all the time and trigger the solenoid [less initial delay])
At that point, you can either tune for the AFR drop from the sudden hit of extra fuel (so pull fuel from tune, or go with more timing based on the added fuel), or leave it be and use the cooling/extra fuel as a safety blanket.
You can always fall down the rabbit hole of what you want to spray as well; meth...50/50...straight water
We want to use it more for safety. The car only runs 7 psi max, but it can't be intercooled. Just wanted a cooler charge. I don't know how much I can actually tweak the tune with the software I have.
BTW, I'll take the nozzle. Let me know how to pay.
