Hey, Haven't been around in a while. Finally spent a few bucks toward the '57 project on suspension work. I'll be looking at the fuel system before long. I've considered using an LS1 external pump kit with the Corvette style filter/regulator which would allow me to run the return line back to the filter versus all the way back to the tank. I got to thinking the rail mounted regulator may fight against the filter regulator because the LS1 system pressure is higher(~58psi Vs. ~43psi). Anybody ever tryed this? I also got to thinking that I may be able to just run the return line back to a Tee fitting at the pump inlet. Opinions, thoughts, personal experience?
