New to me 94 6 speed with some issues.
Okay, I ended up trading my 94 B4C car for a 94 6 speed car. I've had to go through a few hours of different wiring issues and fix a few connections. An issue that I'm having is that the car will only start up if starting fluid is sprayed into the intake before you crank. Once it is running, it will hold idle. It is throwing an SES light, but I wont have a scanner available to me for another day or so. I"m assuming this issue would either be in the fuel pump itself or possibly the temp sensor in the water pump? The guy I got the car from had just recently put a junkyard motor in it, so I'm not sure of the conditions of any of said parts. Also the SES light didn't kick on until about 30-45 seconds of running. Any ideas?
