as the title states, what is easier to use etc and has more or less the same support as say cats for obd1? i need something for the 96 impy now to do some things (emissions off, shift points, fan temps, desired idle, etc.) thanks
haven't used jet but it was bought from tunercats so i think its the same.
so with that said between tunercat and lt1 edit, lt1 edit is a little less intimidating at first, along with gear change stuff is slightly easier.
but in the long run they both do the same, i now just use tunercat and havent touch lt1edit in years...
also another option if you dont have to worry about under the dash emissions scanning is just do a obd1 swap and get tuner cats. might be the cheaper route.
in an impala it isnt, as the tach wont read correctly and some other things. plus, i have under the dash emissions. ill prolly grab dst, amazon prime for $330 lol
no worries thanks
