Advice on 383 stroker build!!
Hey guys I'm planning a 383 stroker build. Well to start I have a fresh factory 4 bolt main block and I'm planning on doing fully forged and spray it a bit. I need help deciding what parts are going to be the best for my build. So of course a nice forged crank scat or Callie's depending on how everything works out. And should I run forged h beam rods and whst size. And what brand and forged piston should I run. I'm looking to get the best compression u can on pump gas and be safe for spray. And defiantly looking for a big cam some where in the 600 lift or more. What size rr should I run also 1.6 or 1.7. Also should I run sa or NSA and what brand of guide plates and rockets should I use. The heads will be ported bigger valves all the good stuff and patriot gold springs and Manley valves. And what's the best head gaskets to run. Thanks for the help
