Turbo 400 setup trade for t56 setup
I have a complete, everything you would need, turbo 400 long tailshaft setup. Transmission is out and being rebuilt. It will be brand new and have the good stuff in it. Torque converter is a 10" tci that I was going to send off and have restalled for my car, its a 2500 as it sits. Shifter is a b&m pro ratchet with cable. It also has the bmr crossmember with torque arm relocation, takes the torque arm off the tail shaft. It will come with the correct driveshaft and correct flywheel and a stock trans dipstick. There will be nothing needed but a little bit of fluid.
I would like to trade for a T56, slave cylinder, clutch, flywheel, crossmember, shifter, and driveshaft. My car was a 6spd and still has the pedals and reservoir. I would also need the upper console piece, rubber and would trade my "custom" made console piece. It actually looks nice. I ask that your trans be in good shape, not jumping out of gears or grinding. I'm being honest and expect the same in return.
The reason for change is I'm wanting to get into auto cross and really miss banging gears. The trans will go back in my car when done if no interest.
Can contact me here or email with any questions buddyweiser38@gmail.com. that goes directly to my phone.
