removing tcs
The huge solenoid on the drive side valve cover that clutters the engine bay is for the traction control correct? I want to remove it as to I never use that nor do I use cruise control. The car is my DD so even if I had to give up ABS I would be fine with that.
From what I understand I need a throttle cable from a non traction control car but I am having a difficult time finding one. Is there any other way I can get rid of what I have without having to find a cable?
Thanks in advance.
Not unless you relocate it, but even then there's not much cable play the get it out of sight.
Sent from my ADR6400L using Tapatalk 2
Does orileys or napa or autozone not carry the single throttle cable?
SMOKE TIRES NOT DRUGS
No I tried all the local parts stores.
Nope, you need the cable to get rid of it. Try the dealer, sometimes they stock extra parts in the warehouse. That's how I got mine a few years ago. You don't have to lose ABS either. Read my posts in here.
http://ls1tech.com/forums/lt1-lt4-mo...r-removal.html
