clutch dragging/ not fully disengaging
this is the second time i've had this issue, both times have come after beating on it at the track. i'm not sure what the cause is, but it is VERY hard to put in 1st and reverse when first started up, and once in gear the motor drops a couple hundred rpm's and it even rolls some. put it in neutral and its fine. with the engine off it will go into gear just fine
my knowledge tells me the pushrod on the slave is not fully releasing off of the clutch fork. any recommendations? i was thinking maybe the drill mod might allow it to move enough extra fluid to fix it
