Loud rearend whine from pumpkin!!
Ok i just purchased this car and im trying to get it on the road. I posted a video of me shifting 1-4th gear. Not going much faster and you can hear how it gets significantly louder. I just want to know if u guys know what the problem could be before i start disassembling the rear.
http://s329.photobucket.com/albums/l...royah006-1.flv
ok since i dont have a lot of cash right now, i unbolted the caps on the diff and unbolted the driveshaft. I also took out the axles. When i spin the pinion it isnt as smooth as it was before. I believe it could be the pinion bearing and if i replace all of the bearings and crush sleeve could i just bolt it back up resetting the backlash?
Sooo would i need new shims at all and the ring and pinion should be fine correct? I saw no chips or anything on either.
Im gonna order my parts soon so i need to know what would be best to do and where is the cheapest.
http://i329.photobucket.com/albums/l...ndkylei030.jpg
http://i329.photobucket.com/albums/l...ndkylei029.jpg
Here is a video of the sound before i pulled the cover off.
