Results 1 to 5 of 5
07-28-2022, 02:31 PM #1LTx Guru
Replica ZR1/Grand Sport wheels - 17x11, 17x9.5
S O L D - 11/28/22
Set of 4 AFS ZR1/Grand Sport offset replicas, with or without OUTDATED tires. Polished aluminum with clear coat. Used occasionally on my 1994 Formula. Purchased new in 2002. These are “MADE IN USA”, not the later “Made in China” versions with a more squared off appearance of the spokes.
FRONT - 17”x 9.5” 56mm offset (~7.5” backspace) - BFG g-Force T/A KDW 275/40-17
REAR - 17”x11.0” 50mm offset (~8.0” backspace) - BFG Comp T/A Drag Radials 315/35-17
The fronts fit perfectly on 4th Gens, the reas are borderline and MAY need modifications. See details in this link:
https://www.camaroz28.com/forums/whe...2/#post3422887
Overall condition is very good. No curb rash, 3 tiny smudges on one wheel, one tiny ding on another. Couple “fisheyes” in the clear coat that were there when I bought them. Toward the rear of some spokes there are “squiggles” of oxidation where clear coat is thin.
Center caps have a simple black circle. I covered them with bright metal disc decals, and added red Pontiac arrowheads. Decals are starting to wrinkle from age and can easily be removed. Wheels have metal valve stems.
Asking $600 with or without tires. Prefer to deal locally to avoid shipping. I'm in East Brunswick, NJ. Will deliver within reasonable distance, or meet half way. Willing to make a longer drive based on a mileage rate.
TIRES LOOK BRAND NEW, FULL TREAD. UNFORTUNATELY THEY ARE 20 YEARS OLD AND SUITABLE FOR “SHOW” PURPOSES ONLY.
Photos in next post.Last edited by Injuneer; 11-28-2022 at 05:15 PM. Reason: Reduced Price
07-28-2022, 03:55 PM #2LTx Guru
17x11 #4 and #6 show the typical "squiggles". #5 is the only nick on this one. I can never figure out how to keep some of the photos from rotating.
07-28-2022, 04:06 PM #3LTx Guru
Typical rear markings for all wheels:
07-28-2022, 04:11 PM #4LTx Guru
Other three wheels, and center cap without decal (ignore the extra long studs needed for the Weld Pro-Stars).
07-28-2022, 04:17 PM #5LTx Guru
3 nicks on one of the 11" wheels. Some stuff fell off the rafters in the garage attic, and was heavy enough to knock the sheet rock loose. The sheet rock landed on the Formula and did no damage at all. But an old cast iron exhaust manifold just nicked the edge of one wheel....
