Results 1 to 10 of 61
Thread: 95 Formula
05-06-2020, 12:29 PM #1LTX Member
- Apr 2020
- Jake D Janssen
- 1995 Pontiac Firebird formula
- 47
95 Formula
I bought the firebird in 2007 with maybe 50k on it. I have not had to do much but minor maintenance since then. It now has 70k. The car has always been a second car but something always came up to prevent me from upgrades. All I've done to it since then is add a stereo, cat back, racetronix fuel pump kit, and egr/air delete (and the supporting tuning). It's always had a small oil leak that bothered me but I never had the time to fix it. I've spent allot of time upgrading the gsxr, flipping my first house, getting married and having 3 kids. Now it's firebird time, I have every other week off work due to covid 19 and I needed a project. I decided to finally fix the oil leaks on the old bird. There were leaks at the front and back of the engine along with the A/C compressor. I decided to pull the engine and K member and clean everything up real well. It's also getting LE2 heads and cam, long tubes, and a few other engine bits. I decided I might as well replace those decarbons also since they suck. Here's a few pics of my progress so far.
05-06-2020, 12:34 PM #2LTX Member
- Apr 2020
- Jake D Janssen
- 47
The engine internals look good. The heads also cleaned up nice. I had my 8 year old daughter assemble the shocks last night, I hurt my knee and couldn't get around very well. Shock install into the K member will be tonight.
05-07-2020, 06:03 AM #3LTX Member
- Apr 2020
- Jake D Janssen
- 47
I have the k member all ready for the engine. New Moog ball joints, Strano springs, Koni sport sa shocks, poly motor mounts, resurfaced rotors and Hawk HPS pads. Next up is to get the cam in the engine and install the intake.
05-07-2020, 09:19 AM #4LTx Guru
- 2,279
Nice clean work.... impressive!
05-07-2020, 05:37 PM #5
Welcome! Let's see more pictures
Sent from my SM-G930V using Tapatalk355 LT1 Turbo, Ported TFS heads, LE Ported Intake, LE cam, 80lb inj, Dual pumps 340 & 320lph on e85, etc.....
www.fquick.com/SleepyZ
05-07-2020, 08:57 PM #6LTX Member
- Apr 2020
- Jake D Janssen
- 47
I started polishing the intake and throttle body tonight. I'm not finished yet but I like how it's turning out. I also cleaned up the wire harness and the engine bay.
Sent from my GM1917 using Tapatalk
05-13-2020, 09:09 PM #7LTX Member
- Apr 2020
- Jake D Janssen
- 47
I was able to get the engine together. The cam had 0.057" of end play vs. 0.015 stock but Lunati said it wasn't an issue. I also had to remove the dowel and install a longer one.
Tomorrow I want to get the engine into the k member, get the headers and clutch installed and make the plug wires.
05-15-2020, 07:59 PM #8LTX Member
- Apr 2020
- Jake D Janssen
- 47
These xs power headers are terrible. I might have to junk them. I had to significantly grind the drivers side k member to get them to fit. The y pipe just barely slides together, maybe only 1/8" at each joint. I can deal with those issues. Now the steering shaft isn't even close to fitting. I've moved the steering column as far to the outside as possible, upgraded to the ls1 shaft, installed new poly motor mounts. I still need another inch for clearance! I don't know what to do. And one of my msd wires were bad out of the box. I got hung up on by msd twice today after waiting on hold for 15 minutes each time. Advance auto can't really do an exchange even though the website says there is a 90 day warranty. On the plus side the spec clutch install went great!
05-15-2020, 08:37 PM #9LTX Member
- Apr 2020
- Jake D Janssen
- 47
Good side vs bad side
05-15-2020, 08:43 PM #10LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 198
I had to put a dent in one of mine to clear steering shaft.
