Page 7 of 8 FirstFirst ... 345678 LastLast
Results 61 to 70 of 75
  1. #61
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Those are the 7/8 ones right?
  2. #62
    1 7/8" that neck down into 2.5" collectors. counterproductive don't ya think?
  3. #63
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    They didnt seem right. For sure . I knew this guy who plumbed his drag boat fuel system. With 3/8 To a filter reg combo then ran 1/2 to twin quads asked him dont you think thats counter productive? Go big stay big I say.
    I dont live to work.I work to live
  4. #64
    Jun 2017
    Brandon Holtmeier
    1996 camaro ss
    So I just got done doing this. I got lucky and found a shaft out of a V6 Camaro with the f41 suspension for $35. I then took it to a local shop to reclock it and he did it for free. The steering wheel is still slightly off center, but not much. Should I just get an alignment?
  5. #65
    Quote Originally Posted by slikrider20 View Post
    you could try, it may correct it
  6. #66
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    F41 is that like the WS6?
  7. #67
    Jun 2017
    Brandon Holtmeier
    1996 camaro ss
    I have no idea. I was under the assumption that the V6 camaros came standard with the rag joint, and well, this did not. The junkyard guy mentioned it had the F41 suspension....that's about all I know.
    Hopefully the alignment fixes it.
  8. The Following User Says Thank You to slikrider20 For This Post:
  9. #68
    Cameron
    Dover, De
    F41 is the RPO for the normal v6 rack...3 turns lock to lock
    If it had a LS1 rack it was a Y87 car. That car would've had 3.42's, LS rack (FE2) and springs and rear disks
    Formula Build Thread
  10. The Following User Says Thank You to Sahara54 For This Post:
  11. #69
    Jul 2015
    Heath Carfrey
    1997 Ram Air Trans Am
    Grove City, OH
    Stupid question: If you can reclock the steering wheel why is modifying the shaft necessary to keep the airbag? Doesnt the wiring run up through the middle column and plug in from there to the wheel and airbag?
  12. #70
    Quote Originally Posted by Afterburner82 View Post
    Stupid question: If you can reclock the steering wheel why is modifying the shaft necessary to keep the airbag? Doesn’t the wiring run up through the middle column and plug in from there to the wheel and airbag?
    the clock spring in the column references wheel position/supplies power to airbag. simply moving the steering wheel does nothing to correct the fact the shaft would be 90 degrees out on the clock spring inside the column
