Results 531 to 540 of 752
Thread: Project; "BEATERBIRD"
11-29-2016, 10:40 PM #531The FABRICATOR!
- Jul 2011
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Your timing set doesn't have multiple crank key ways cut for different advance/retard cam timing by chance does it?
The Following User Says Thank You to firebird_1995 For This Post:
11-29-2016, 10:46 PM #532The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
I'll be checking once I get the motor back
But I don't think so.94 Formula "budget build" #thebeaterbird
11-29-2016, 11:30 PM #533The FABRICATOR!
- Jul 2011
- southern illinois
- 7,164
It's pretty hard to screw up installing a timing set really. Dot to dot is the #6 tdc position but it's the easiest to make sure they're lined up correctly. I'm afraid I would have to question the accuracy of their degreeing method before I would tear it apart. About the only other way it could have been screwed up is if there was no dowel on the cam and you put the cam gear on 120 or 240 off.
11-30-2016, 02:51 AM #534The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
11-30-2016, 10:38 AM #535"The Rock"
@meissen
OWNER/ADMIN
11-30-2016, 08:36 PM #536The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
What is that?
Sent from my SM-N910T using Tapatalk94 Formula "budget build" #thebeaterbird
11-30-2016, 09:21 PM #537LTX Regular
- Nov 2011
- Marc
- 1995 Formula
- magnolia, DE
- 400
Stoopid spammers
Sent from my A621BL using Tapatalk1995 FORMULA M6
The Following User Says Thank You to 95 blackbird For This Post:
12-01-2016, 12:53 PM #538The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Well I am going to work on the motor when I get it back .... but on another subject for the time being .... I measured the drive shaft I got with the th400 and it's 44 1/4 eye 2 eye, total length 46.
With a th400 short tail shaft and stock rear axle is that length sound right?
01-14-2017, 10:25 AM #539The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
well a much needed update ... got a cam ordered from Lloyd Elliott @NightTrain66
235/247 .579/.600 @112 lsa
the cam that was in there was not going to do good with nitrous so he said that this will be much happier in there
so looks like about 3 weeks or so i am hoping to get this thing back together and running94 Formula "budget build" #thebeaterbird
The Following User Says Thank You to zooguy For This Post:
01-14-2017, 10:48 AM #540"The Rock"
