Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Turbo Camaro!
    Jonathan Englund
    1994 z28/1994 formula
    Nebraska
    Default Turbo Camaro!
    Well, I started a build thread for my camaro about a year ago then changed directions. I decided to do a turbo build, and last week I got my first parts for it(hot side). This build will definitely take time to come together. I want to make 1000rwhp but we will see what it makes when it gets done.
    As I sit right now, I have a 1994 camaro z28 roller with a 10 bolt rearend (lord help this poor rearend LOL). I have a build sort of set up...
    38xci LT1:
    Callies Dragonslayer 4340 crank 3.75 stroke
    Callies ultra xd I beam 5.85" Rods
    Diamond custom pistons w/ rings
    Cleavite bearings
    LE Trickflows
    LE Hydraulic boost cam
    GT4788 turbo
    LT1 Boost 88mm Hotside w/ 40mm waist gate
    A2W intercooler
    I am going to run the LT1 pcm and Opti as long as I can
    Single plane intake
    E85
    LC1 wide band
    4L80e swap
    Want to find out if there is a way to control the 4l80 with the lt1 pcm
    10 bolt till it breaks then go 9"
    Suspension and a cage will come after I get the car moving under its own power.
    this thing has been sitting way to long lol
    1k is a tall order. Im definitely subscribed. Please keep this updated, and keep the pics coming.
    Can i make one suggestion tho. Start with the rear... then the suspension... then the trans... then the powerplant. That way, u can use it when u build it. I did ny boost build motor first and it took years to get it right.. then it took more time to make it where I could use it, and Im still a strong driveshaft short from being able to stick the power... and thats only 602rwhp.
  3. The Following User Says Thank You to popo8 For This Post:
  4. #3
    Jonathan Englund
    Nebraska
    @popo8 the trouble is, I need to get the car out of that shop and moving as soon as i can, so that means getting the drivetrain in and going. My dad wants his shop space back rofl
  5. #4
    The FABRICATOR!
    southern illinois
    You can run an 80e with an lt1 pcm. Several guys here doing it. I'll be listing mine for sale soon
  6. The Following 2 Users Say Thank You to firebird_1995 For This Post:
  7. #5
    Quote Originally Posted by englundjd View Post
    I understand. Just wanted to throw out what mistakes I learned from.
  8. #6
    Jonathan Englund
    Nebraska
    Yea I may start ordering some of the smaller suspension parts but the bigger stuff will have to wait till I get it moving.
  9. #7
    Jonathan Englund
    Nebraska
    do you know how it is controlled? does the tuner just trick pcm into thinking its a 60e?
  10. #8
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    Sounds like an interesting build. Did you pick 1000rwhp as the goal since its a nice number? Its certainly not impossible but rare for a LTx. Who is building the engine?
    17 Corvette Z06 - 11.05 @ 125
    17 GMC Sierra Denali Dmax
  11. The Following User Says Thank You to blackbirdws6 For This Post:
  12. #9
    E85, 1000whp, and turbo... better be prepared to spend a few grand on fuel pumps and lines.
    Is it a T4 88mm?
  13. #10
    Jonathan Englund
    Nebraska
    Quote Originally Posted by blackbirdws6 View Post
    There is a couple shops here in my home town that have good reputations, I'm also about an hour away from Omaha NE which also has some options as far as machine shops and engine builders. I need to do some shopping around.
    As far as horsepower is concerned I'd be happy with ~800 hp on a dyno but I want to be able to support 1000 so if I get the itch to make it happen I can.
