Page 5 of 18 FirstFirst 12345678915 ... LastLast
Results 41 to 50 of 176
  1. #41
    passenger side ltcc coils and plug wires in, egr blocked off. am going to start working on the fuel line relocation, as i am going to mount my ltcc where the stock lines come out behind the fuse block. gonna actually try to hide some of the ltcc wiring this time too.
  2. The Following User Says Thank You to SSlowBoat For This Post:
  3. #42
    We want photos......
    Is the LTCC setup obsolete or still in production? I thought they went under?
  4. The Following User Says Thank You to JOATMON For This Post:
  5. #43
    if you email bob bailey he will still sell them, he is doing limited production when he has enough orders (like 5 or 10).
    honestly i got mine used back in 2017, and it was already 3 years old, it worked fine then so hopefully it still works.
  6. The Following User Says Thank You to SSlowBoat For This Post:
  7. #44
    after talking to @Catmaigne about his car this week, got a little bug to work on mine. @Ltconvert came over and we buttoned up the LTCC and @Fastbird fuel line relocation. I forgot i drained the oil so first start will have to wait until tomorrow.
    need to get:
    grommets and spacers from lowes for ltcc box mount and also fuel lines thru body.
    oil change.
    hose for steam line to rad, hose clamps for rad.
    water pump gaskets and wire in water pump to air pump relay.
  8. The Following 3 Users Say Thank You to SSlowBoat For This Post:
  9. #45
    hey @JOATMON , it fired off today
  10. The Following 3 Users Say Thank You to SSlowBoat For This Post:
  11. #46
    Sounds sweet Man, congrats.
  12. The Following User Says Thank You to JOATMON For This Post:
  13. #47
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    FYI for safety I'd put grommets around those fuel lines where they pass through the shock tower.
    Sounds healthy!
  14. The Following User Says Thank You to Fastbird For This Post:
  15. #48
    Sounds healthy!
    Already did, pic was pre lowes trip.
    Thank you
  16. #49
    Long Live the Opti
    Sean
    Fort Wayne, IN
    Lol, I figured you'd be on top of it, but gotta call it out when the pic shows it!
  17. The Following User Says Thank You to Fastbird For This Post:
  18. #50
    for @Fastbird
    snapped a water pump bolt. destroyed 2 sets of bits drilling it out, and its ate 1 tap so far. need a sharper tap. fml
