Page 10 of 18 FirstFirst ... 67891011121314 ... LastLast
Results 91 to 100 of 176
  1. #91
    1994 Trans Am
    PA, USA
    Shortly after I got my car, I ported the intake with a carbide bit on the car after shoving a wet rag in it. It was hideous and eventually was machine ported (aka cleaned up my hack job. Ah yes, the days when you just assume a totally stock LT1 will make more usable power with a junk Summit 58mm TB.
    I'm looking forward to seeing your car in action. You are anticipating breakage at some point, but it will probably last forever. ...until the 300 shot.
    Edit - Nice job!!
  2. The Following User Says Thank You to harner For This Post:
  3. #92
    Quote Originally Posted by harner View Post
    Edit - Nice job!!
    Thank you. I stuffed a cut up t-shirt covered in wheel bearing grease in the intake to catch the aluminum, along with plugging the iac hole with a rubber cork/grease, and pipe cleaners in the pcv openings behind the divider (again grease covered). it looks like i got 98% of the shavings out. used a dremel grout removal bit to rough the opening, then 60 grit sanding drums on the dremel to clean it up. It actually went surprisingly well, and it looks decent enough that my fiance thought i got an intake from someone, she said theres no way you did that with a dremel
    just gonna keep plugging away at it. i know i need a converter and trans more than anything, so thats the goal right now. but if for whatever reason i cant get one before track season, its getting sprayed the way it sits.
  5. #93
    tore down the le2 motor to help out jay with his issues. hes getting my le 227/235 cam and le2 heads, those funds will go to @Ltconvert for those le ported afr heads he has and the nitrous cam that was specd for a 355.
  6. The Following 3 Users Say Thank You to SSlowBoat For This Post:
  7. #94
    so i did a thing this weekend
    NICE!
  8. The Following User Says Thank You to popo8 For This Post:
  9. #95
    wonder if these will work on a stock bottom end. they have been cut to 55cc and are hogged out 195's by @NightTrain66
  11. #96
    How do they flow?
  12. #97
    How do they flow?
    allegedly like 315 at .700
  13. The Following 2 Users Say Thank You to SSlowBoat For This Post:
  14. #98
    drunk cc'd the chamber on the afr on @Ltconvert kitchen table at his new years eve get together LOL. 55cc, so .040 cometic ordered.
    also ordered some universal nx solenoid brackets.
  15. The Following User Says Thank You to SSlowBoat For This Post:
  16. #99
    this will probably be nitrous solenoid final mounting. fuel solenoid will be on ds, but need a few fittings and a new hose as the supplied is not long enough to grab the rail shrader.
  17. #100
    Bottle mounted. I know i need a nhra blowdown etc. this bottle is out of date and will get sent in as a core for a new nitrous outlet bottle with the gucci valve/blowdown. i dont have a need for the remote bottle opener so if anyone wants it its up for grabs. 20210110_161949.jpg
