Results 1 to 10 of 11
Thread: Oil pan leaking FML
10-23-2009, 11:55 AM #1InActive Member
- Oct 2008
- Carbondale, Pennsylvania, United States
- 654
Oil pan leaking FML
Can you do the oil pan gasket with the motor all bolted into the car or what? It looks like its gonna be a tight squeeze to get the pan down. My pan is dented in the bottom so I wanted to do a canton pan and new gasket because of the leak and dent. Just wondering how big of a job it is and what I need to do.
Cammed, bolted, Geared
LE, UMI, Strange
10-23-2009, 12:11 PM #2"The Rock"
undo motor mounts, lift on motor....
loosen 6 K member bolts and allow it to drop...
just enough room to get pan out...
10-23-2009, 01:01 PM #3
You can do the pan with the motor in the car, without dropping the K member. Did it last season, alot easier with less work.
Not sure if the canton pan is lower/shaped different, might want to check on that. The stock will come out, and will go in by just unbolting the motor mounts and jacking/hoisting the engine. Make sure you arent crushing anything of course.Last edited by Fixxer99TA; 10-23-2009 at 05:12 PM.
Nick
10-23-2009, 01:12 PM #4"The Rock"
10-23-2009, 01:24 PM #5
Yep, done it multiple times and once to my own because of some other hacks having it before me (Stripped drainplug and a small leak that crept up).
Not to mention the pan only needs to be dropped down a little to do the repair he describes (just the gasket).Nick
10-23-2009, 01:31 PM #6"The Rock"
10-23-2009, 03:32 PM #7InActive Member
- Oct 2008
- 654
Yeah I actually wanna put a new pan on and i figured id upgrade to the canton maybe ill just put a new factory one on because mine is dented, but thats good to know i just have to lift up the motor a tad. Thanks guys.
LE, UMI, Strange
10-23-2009, 06:13 PM #8
whether or not the pan will come out depends alot on A4/M6. I struggled for hours to get the one out of my M6... i almost couldve dropped the engine in the time i spent.
- Joel - 95 Z28 M6
"It's an ingenious solution to a problem that should never have existed in the first place!"
10-23-2009, 06:54 PM #9
I have an M6 and I did not have to drop the k-member. it took about 3 hours. make sure to under it again in a few days and make sure all the bolts are still tight.
LT1, M6, CC306 cam, Comp 918 springs, Hardened pushrods,Ported TB, TB Bypass, Descreened MAF, 4:10 Gear, pacesetter LTs, custom exhaust, Some Suspension Upgrades...
Near future: LE2 package
10-23-2009, 08:29 PM #10
1995 Black Trans Am LT1/4L60E 14.48@96mph
Mods: 17" Corvette GS replicas, K&N panel, MSD wires, NGK iridium plugs, Ram Air box and hood 3.42 gears
