Results 1 to 10 of 12
Thread: big HP
09-30-2009, 01:22 PM #1
big HP
Hey I have a 97 z28 with a vortech v1 supercharger running 5psi. my dad just bought a 2002 zo6 and i want to be faster. he can still walk me pretty easly and he is now starting some mods. the thing is i need to squeez about 100hp out of the car with out running nos or building the engine. the engine runs really strong and is very well maintained but it does have 145k miles on it. what should i do to get the hp i need.
97 Camaro lt1, built t-56 by nick at newtech, spec stage 2 clutch, ritchmond 4.10s, BMR adj. torqe arm, tb bypass, custom exhaust with glass packs, Tuned with Jet DST by myself, 160 deg termo,vortech supercharged! best et. 13.57 at 103.2 mph 2.02 60' on street tires N/A before supercharger. new numbers soon
09-30-2009, 02:10 PM #2Lurker
- Apr 2009
- Rob Warrick
- 95 Camaro z28
- Lexington NC
- 549
some 1.6rr and run more boost just 2 things to start
edit: i just read that you still hav the stock exhaust manifolds on. you need some headers. go atleast with midsLast edited by z28rob18; 09-30-2009 at 02:15 PM.
09-30-2009, 02:15 PM #3
3.125" pulley (I have one if you want)
1.6 rr's
electric waterpump
EDIT: Headers of any type, preferrably full length.
You should be around 410rwhp with that stuff. I made 406/413 with just LTs and the 3.125" pulley. The car only had 30k miles though, which is why I put you at 410. Plenty enough to walk it.-Zach-
1995 Z28
09-30-2009, 02:18 PM #4
any ideas? if its not in my sig i don't have it done. do you think some headers and bigger tb and 1.6 rockers will make a big difference?
09-30-2009, 02:21 PM #5
09-30-2009, 02:21 PM #697 Camaro lt1, built t-56 by nick at newtech, spec stage 2 clutch, ritchmond 4.10s, BMR adj. torqe arm, tb bypass, custom exhaust with glass packs, Tuned with Jet DST by myself, 160 deg termo,vortech supercharged! best et. 13.57 at 103.2 mph 2.02 60' on street tires N/A before supercharger. new numbers soon
09-30-2009, 03:03 PM #7
Honestly just figure out why it's not making boost and you will easily pull him. You have too be losing boost somewhere...
I made 6psi with a stock LT1, 6" crank, 3.33" blower pulley only difference from your car is I had Edelbrock shorties. I would think you should at least be at 7 or 8 psi.Brandon
94 Z, 383, 6-Speed, T-Trim, Aftercooled, AFR, DFI, Moser, Etc....
95 Z, DD, Bolt-ons + 125 Shot
02 GMC Sierra 1500 Ext Cab, Car Hauler
09-30-2009, 03:45 PM #8
the belt is tight and all the clamps are tight. what else could it be? I had a 3.33 and only made 1.5psi
09-30-2009, 08:38 PM #9"The Rock"
09-30-2009, 09:39 PM #10
What is your AFRs?
Something is not right if u still only hitting high 13s.
