Results 1 to 7 of 7
09-24-2008, 09:19 PM #1InActive Member
- Chattanooga, TN, currently at Little Rock AFB
- 527
LCA relocation brackets lift rear?
My friend installed some LCA relocation brackets, and we all agreed the rear end looked like it sat higher. Did anyone else notice that after installing brackets?
Also the "rear hose" mod where it drops the rear looks like it sits a little too low, I'm curious if the brackets raise it a little, and the hose mod drops it a little, how would it look? Has anyone done both of these mods and have pics?-Tim R.- 2001 Trans Am WS6 M6
Patriot 225/229 .580/.590 114+4
09-24-2008, 09:38 PM #2
My car does not sit any higher or lower, no matter which of the three holes I put the lca in.
You said it 'Looks' higher... How about you move the lca to the stock hole and measure from the ground to the top lip of the wheel opening. Then put the LCA's in whatever hole in the relocation brackets and measure again.
If it is actually moving the rear end then there is something wrong with the install.- Justin
Custom tuning with HpTuners and your most common standalones.Originally Posted by WJ Birmingham
09-24-2008, 10:13 PM #3
relocation brackets will not make it higher. only springs can change that.
93 TA, 383 stroker, ATI procharger, Accel DFI Gen VII, TH400 RMVB w/Tbrake, narrowed moser 9 inch.
09-24-2008, 11:31 PM #4InActive Member
- 527
Well, we never knew for a fact, we just thought it "seemed" higher. so i was just checking..
I might still do the hose mod though.-Tim R.- 2001 Trans Am WS6 M6
09-24-2008, 11:40 PM #5
Could have been sitting higher for a bit if you had the load of the vehicle off the rear springs. The springs probably just needed to settle back down...
09-25-2008, 10:14 AM #6
My UMI bolt in relocation brackets didn't raise the car but did push the rear end towards the rear bumper a bit, but a set of adjustable arms corrected the problem.
'95 Z28 M6, Bolt ons, C5 Brakes, UMI/Strano Suspension
'68 Camaro 355, TKO 600, Global West Suspension, C5 Brakes
'01 GMC Sierra C3, 6.0 LQ4, AWD, 5k HID, 20" Chrome Denali Replicas
The Cars
09-29-2008, 05:33 PM #7
LCA Bracket's wont lower or raise the car...did you all happen to take the springs out?
