Results 1 to 10 of 16
06-09-2009, 12:45 PM #1
aftermarket shifters in an A4 95 Z28?
Help me out guys, I'm trying to figure out that the two cables do that move when you push the shifter button down do. Can you bypass those cables and bolt an aftermarket shifter in there? I'm asking this because I have a Hurst dual gate shifter out of a 60's GTO or Olds 442. So how do you guys with race cars have the dual gate or B7M shifters in your 4th gens? Any help of write up's would be awesome!
95 Z28 hard top - LT1, 4L60e, bolt ons, Yank SS3600, suspension, viking coil overs, 3.42 10 bolt, 3320 lbs - 12.304 @ 108.52mph 1.69 60'
08 Saab 9-7x - L96 6.0 swap, L92 heads/intake/TB, LS6 cam, LS9 springs, 7.425" hardened pushrods, CAI, 1-3/4" stepped LT's, catback, 4L60E, FTI 3000 278mm converter
06-09-2009, 12:56 PM #2Banned
- Big Papi
- 2015 Fusion Titanium AWD
- Moscow Mills Mo
- 7,241
- Blog Entries
- 1
If your still running the 4l60e your doing more harm than good , Other than that if I recall you should have the one that releases the shifter and the main cable the goes down to the trans
06-09-2009, 01:26 PM #3
yes there are two cables that move towards the firewall when you press down the button and the obvious shifter cable that goes to the tranny. I should mention too that I have the 2.73 gear rear end so my factory shifter only goes down to 2nd gear can't shift into first, that is the main reason I want to do this combined with looks . and yeah I have an untouched 4L60E.
06-09-2009, 03:39 PM #4
Anything is doable with some fab work involved.
1996 Z28/SS #2152 Speed Inc./RGR 355ci H/C/I/ FLT/Yank/BMR/UMI/ Nitrous Outlet...
2011 Extreme Steet Power Adder..Blew Up
2010 Extreme Street Power Adder Champ
2009 Extreme Street Power Adder Runner Up
2006 TB SS - AWD DD and Tow rig
06-09-2009, 04:22 PM #5
Yeah I'm not going to have a problem bolting the shifter in and using an M6 console with a boot to cover it, but I just don't know how to avoid those two cables...
06-09-2009, 06:08 PM #6
here is a write up. hope i helped!!!
http://www.ls1tech.com/forums/appear...-write-up.html
1995 Z28 LT1| Built 4L60e| Small Vette stall| Transgo Stage 2 Shift kit| SS Spoiler| Flowmaster Cat-Back| Cut-out| !Cat| Descreened MAF| K&N CAI
06-09-2009, 06:28 PM #7InActive Member
- Oct 2008
- Jim
- 1996 Z28
- Sugar Grove IL
- 1,243
One cable goes to the column for lock out, the other is the shift cable.
1996 camaro Z28, Clayton racing 398, Rossler TH350 rmvb with brake, FTI billet race converter 4400, Dana S60 with 4.10's, 300 shot, Accel DFI controlled, UMI, Spohn, PA racing, QA1's, Baer brakes, 325/45/17 M&H, Caged, Corbeau's, Simpson, etc.
From zero to fuck yeah in 3 seconds.
06-09-2009, 08:38 PM #8
Ahhh thats what they do... Well it doesn't look like I'll be getting my dual gate mounted in there!
06-11-2009, 02:29 PM #9
i wonder if an off the shelf shifter ball would work and if they come with adapters?
1996 Z28: original paint, full boltons, cam, stalled, sprayed - sold
2001 Dodge Ram 1500 4x4: Little bit of lift, 33's, dumped Thrush muffler
06-11-2009, 05:42 PM #10
