Page 8 of 8 FirstFirst ... 45678
Results 71 to 75 of 75
  1. #71
    Mar 2021
    Michael
    94 Camaro Z28
    I know this is an old post, but I need help with this. I'm having a hard time knowing what exactly I'm supposed to grind off. I've grind what I I thought was the tabs and I still can't get the two pieces to separate.
  2. #72
    you have to grind the center area flush to the knuckle, then beat the hell out of it to get it off.Grind1.jpg
  3. #73
    10 Second N/A Club
    Josh
    96 Z28
    Holden, MO (KC)
    ^^What he said, even then it's sometime a real PITA to get them to separate, especially if the shaft has a lot of corrosion or rust.
    -Josh
    co-owner of BDBRacing.com
    NMCA OC 9004
  4. #74
    Mar 2021
    Michael
    94 Camaro Z28
    Thanks! That helps a ton. I got that part ground down but I'm still having a hard time separating the two pieces. Is there a best place to strike the shaft to get them to separate?
  5. #75
    Cameron
    Dover, De
    I've done it a few times and had to use a vice and a air hammer on the face above each crimp.
    Formula Build Thread
