Results 1 to 7 of 7
04-20-2023, 08:01 PM #1LTX Member
- Jan 2014
- Pete Birrell
- 1996 Impala SS LT1
- Niagara Falls, Canada
- 55
Will a PCM fire plugs on a carburated LT1
I am working on a '29 Ford roadster and thinking about installing a sbc. For a Gen I engine you have to cut the firewall to clear the HEI distributor.
I was thinking I could use a smaller points distributor without the cap using a carbed Gen II engine. The points could make and break the circuit to the coil, firing through an Opti up front just for distributing the spark.
Then I ran across this old article from Hot Rod inferring a PCM could spark the engine using a GM Perf. carb intake (which I have). Then I could just put a freeze plug in the distributor hole.
Do you think the PCM would fire it with no injector hookup without going into limp home mode.
Currently the car has a 78 Regal carbed turbo V6 motor sitting in it, but it's seized from sitting for 30 years.
Pete
1997-08 Hot Rod Mag LT1 intake.jpg 20230419_29 Ford.jpg1996 Impala SS, LT1, Edelbrock headers, MSD, K&N, 1962 Pontiac, LT1 4L60E swap
1956 Ford Victoria, '95 Vette Lt1, GM Perf. Parts intake, Holley Ultra 750, GM Hot Cam,
1978 Malibu 400 sbc ( collecting pieces for LT1/4l60E swap)
The Following User Says Thank You to rwd_pete For This Post:
04-23-2023, 12:13 PM #2Xtreme Member
- 7,269
Supporting Memberi believe it would. there is not really a limp mode for these cars besides check engine light on and fans on.
im looking into using a carbed lt1 in a swap BUT using a ls ignition controller to drive 8 ls coils with a torqhead sensing unit
Sent from my SM-S908U using Tapatalk2021 Charger Scat 392
04-24-2023, 09:47 AM #3LTX Member
- Jan 2014
- Pete Birrell
- 55
Thanks for your comment. My Impala SS went into a limp home mode once, but it was a tranny issue and it stayed in low gear. I guess that that's the tranny side of the PCM brain. The coil on plug setup sounds like a nice modern way to make it all work.
Pete1996 Impala SS, LT1, Edelbrock headers, MSD, K&N, 1962 Pontiac, LT1 4L60E swap
04-24-2023, 09:48 AM #4Xtreme Member
- 7,269
04-24-2023, 11:10 AM #5LTx Guru
Supposedly there is a sub-program in the PCM that covers the limp mode. That is only intended to keep the engine running when almost all sensor input is lost. Key word… “supposedly”.
04-24-2023, 11:30 AM #6Xtreme Member
- 7,269
04-24-2023, 03:38 PM #7LTx Guru
GM calls it Back-Up Mode (also known as limp-home mode). It would not be useful for anything other than moving the vehicle off the road. Uses only distributor reference pulses, throttle position, and coolant temp. Implemented when ECM cannot operate normally. Conditions causing:
- ECM volts less than 9 volts
- Cranking voltage less than 9volts
- ECM internal circuitry fails to ensure proper Computer Operating Pulses
This is from gmtuners.com. Not specific to the LT1, at one point mentions PROM missing, so Im only assuming the definition was carried over to the fixed chip PCMs.
