Results 31 to 34 of 34
10-16-2022, 12:00 PM #31
@SSlowBoat
I took a quick measurement. When I can get under the car again I'm sure I could adjust the plastic section and move the whole filter down to get somthing longer on there.
10-16-2022, 02:06 PM #32Xtreme Member
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,865
What brand of filter are you running at the moment? CFM of the filter media is equally as important as size when shopping for these. Popular K&N stuff uses a very restrictive media. The Spectre, AFe, and other diesel stuff moves way more CFM per square inch of media (and also puts more particulate into your motor, but that shouldn't matter much unless you live down a dirt road). I'm currently running the biggest Spectre from the parts store which seems to work and was cheap, but I also made a bracket to prevent the top button from getting sucked in.
10-16-2022, 02:25 PM #33
@Catmaigne
Whatever the filter is that comes with the kit.
06-14-2023, 07:59 PM #34
Currently street tuning I have seen 14-15 psi. Up to 18° and seems good
I changed to a larger filter and ks7 knock sensor. Getting some gains on timing and afr changes.
