Results 1 to 8 of 8
Thread: Aftermarket Radiator
05-22-2022, 08:07 PM #1LTX Member
- Oct 2014
- Justin
- 1995 Formula
- Houston, TX
- 82
I'm having problems keeping my 396 cool in traffic. Currently running an ebay aluminum 3 core which seems pretty well constructed. I also have a new stock radiator and they both pretty much act the same.
I don't mind spending the money on a good radiator as long as it solves the issue. What's everyone's experience on DeWitts, ECP, BeCool, etc?95 Cyber Grey Formula
396 M6
LE 244/252 .636/.636 110
LE 215cc Trickflows
05-22-2022, 08:29 PM #2Xtreme Member
- Sep 2014
- Joel
- Colorado
- 1,156
Do you have a stick car or auto.
Sent from my LM-G820 using Tapatalk
05-23-2022, 04:55 AM #3LTX Member
- Oct 2014
- Justin
- 1995 Formula
- Houston, TX
- 82
Stick
05-24-2022, 07:23 AM #4Xtreme Member
- Nov 2008
- Chris
- 1994 Trans Am
- PA, USA
- 2,404
Supporting MemberStock fans? I have a Griffin radiator in my car with a pair of flex-a-lite fans that move way more air over stock. It may be worth trying a different set of fans versus swapping the radiator. Or do both and call it a day. I have no experience with the brands you referenced, but I'm sure they would perform the same or better than the ebay rad.
Chris.
1975 Olds 98 455 burnout machine/panty dropper
2006 Silverado Z71 5.3 "HO" L33/60e, Baby cam'd at 240k | 2012 Escalade ESV Platinum 6.2 AWD, Some audio stuff, DD/Work Car
2009 CTS-V A6 Sedan, Forged bottom end, FED 1.5 heads, She Gone cam, another gd money pit is all it is
05-24-2022, 08:54 AM #5Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,753
Do you have the AC installed? The reason I'm asking is because I have mine completely ripped out and there are huge gaps by the radiator end tanks. The stock shrouding to prevent the gap only works with the condensor, so I was thinking about making my own shrouds using garolite sheets to force more air through the radiator core.
Another thing I noticed is that my engine bay gets super heat soaked with my Harwood. I used to have a cowl hood that had a huge opening by the wiper cowl, but the Harwood seals to it instead. I'm going to cut some vents in the back to see if it helps.
Sent from my SM-A526U1 using Tapatalk96Z M6, ERE-383 #60, AFR 210s, LE cam, 9", Procharger D1, ???whp
05-24-2022, 09:42 AM #6LTX Member
- Oct 2014
- Justin
- 1995 Formula
- Houston, TX
- 82
Yea, I have new LS style fans. do you have a link to the ones youre running?
396 M6
LE 215cc Trickflows
05-24-2022, 09:46 AM #7LTX Member
- Oct 2014
- Justin
- 1995 Formula
- Houston, TX
- 82
yea, i have ac. I'm running a WS6 hood. I've actually been considering swapping to a cowl hood. Or at least remove the hood seal
396 M6
LE 215cc Trickflows
05-25-2022, 08:16 AM #8Xtreme Member
- Nov 2008
- Chris
- 1994 Trans Am
- PA, USA
- 2,404
Supporting MemberSadly I do not. I bought the rad/fan combo from someone many years ago when they were parting out their car. Similar to these: https://www.summitracing.com/parts/flx-105422
I also had the mounting location changed of the rad. Check out my lengthy build thread (link in sig) for pictures. I finally got around to installing the BP Automotive fan controller "recently."
Chris.
