Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Beyond confused
    LTX Regular
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Default Beyond confused
    Fired up my 383 Monday and it idles bouncing between 800-1500. Check engine light is on, all sensors except the map have been replaced. Opti has also been replaced along with the fuel pump. Any time throttle is applied I can hear the intake sucking in air and the car will die. No throttle response no increase in rpm just flat out stall under any throttle at all. Almost ready to wash my hands with it at this point.
    Sent from my motorola edge plus using Tapatalk
    Pull the codes.
    Big cam? Tuned for it?
    LTX Regular
    Sep 2015
    Brandon++S
    1997 camaro z28
    Alabama
    Are you using factory elbow? If so make sure your not sucking air around the silencer hole on bottom.
    LTX Regular
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Pull the codes.
    236/242 and yes sir, I may have found the problem PCM is undetected when I try to scan it.
    LTX Regular
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Quote Originally Posted by Brandon++S View Post
    I'm running an LS lid setup but I've checked for all possible vacuum leaks
    LTX Regular
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Hopefully this pcm will cure my problems I'm exhausted
    Depends if the tune in the replacement PCM is close to the 236/242 cam.
    What were you using to scan it?
    LTX Regular
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Scan94/95 on my laptop. Turns out the laptop I was using was incompatible with the cable software. Dug out my old one and it connects with no issues. Check engine light is on but no code is being thrown which is odd. It's pulling very little vacuum so hopefully I found my trouble I'm taking the intake off right now. I'll double back in a bit.
  9. #9
    A malfunction of the SES light should set DTC 11.
  10. #10
    LTX Regular
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    I was wrong about the intake, everything is sealed. There are absolutely no vacuum leaks. And turns out my cable is bad that's why it's not showing me codes. I'm at a complete loss right now. Attached a video, it's holding idle at 1500 and every time I give it throttle it just starts to die. Really don't know what else to do at this point. http://cloud.tapatalk.com/s/625a2e16...1183806348.mp4
