Results 1 to 2 of 2
Thread: 1997 WS6 build.
05-22-2022, 12:11 AM #1LTX Member
- Mar 2014
- Eric
- 1997 Trans Am WS6 - H/C/I/E, Full BMR, 383, M6
- Cheyenne Wy
- 57
1997 WS6 build.
Finally picked up another project from a local member that's not active anymore (@gojo83). Nothing fancy but has just about everything needed to get it back on the road again. Figure It'll probably be up and running this fall and will get fully finished this winter. Once the car is up and running, I'll start cutting and adding billet pieces for testing.
383 (Scat crank, Callies rods, JE Pistons), cam (I'll update the specs later when I figure it all out), ported heads, ported intake, 58mm tb, electric water pump, hooker headers, nearly complete BMR suspension setup, LS spindles that'll probably receive C6 or CTSV brakes.
20220521_215041.jpgNew build coming soon.
The Following User Says Thank You to 97.Z28 For This Post:
05-30-2022, 10:22 PM #2LTX Member
- Mar 2014
- Eric
- Cheyenne Wy
- 57
Got the car home today and had a bit of time to go through it. Nothing too crazy for the age but needs some TLC.
Need to fix the drivers outside door handle, drivers headlight motor, fender replaced, spoiler swapped due to damage, hood properly installed before I get much more into the car and start putting on all the goodies that came with it.
Last registration expired January 2011, at least it's been in a garage since then.
20220530_175422.jpgNew build coming soon.
