Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: PA Folks
    Default PA Folks
    Fairly certain I can register/tag my car (1995) as a classic, and that gets me out of emissions inspection.
    Is that a fair assessment? Are there downsides to classis tags? For safety inspections (da faq PA) is that a simple inspection or will I get nitpicked over everything? Are the inspections something I can stand there with the shop and watch? (Not overly fond of leaving my car at random shop)
    Thanks
  2. The Following User Says Thank You to shownomercy For This Post:
  3. #2
    Dec 2011
    Mark
    Altoona, PA
    Classic tags still require annual safety inspection but are exempt from emissions. Antique tags require no safety inspection or emissions but you are limited to driving between dusk and dawn. All lighting requirements still apply.
    http://www.dot.state.pa.us/public/dv...ets/fs-ant.pdf
  4. The Following User Says Thank You to 1QUICKZ28 For This Post:
  5. #3
    Move to NJ..... no inspections of any kind 1995 and older. About the only positive NJ thing I can think of.
  6. The Following 3 Users Say Thank You to Injuneer For This Post:
  7. #4
    Currently is NJ tagged, and I am finally getting released from the prison of NJ.
    Ironically, NJ is less intrusive on car stuff than PA. Wacky world.
  8. The Following User Says Thank You to shownomercy For This Post:
  9. #5
    Asshole.
    Nov 2008
    1994 Trans Am
    PA, USA
    Regarding inspections - there is a lot of variation depending on location. Also, emissions is done on a per capita/county by county basis. For instance, I live in Schuylkill County and we never had emissions due to our population. Probably never will, but who knows. If I went to any legit shop in my area, they should still be doing a visual inspection and checking to ensure all smog/cats/etc crap has not been tampered with. Any real car guy knows who to go to and who to avoid. I take my wife's car to the dealer or the garage 1/4 mile away for inspections. I take my piles of crap to a garage that built their own 6 sec 1st gen. I stand around and make small talk while they inspect brake pads, tires, lights, etc.
    I've gone to "lick em and stick em" places where they literally just hand you the inspection sticker and a scraper, but I'd avoid them. They're usually on someone's radar and don't last long.
    Where in PA are you going?
    Chris.
    1994 Trans Am
    Under the knife - who knows when it'll run (5.3 LM7/CPT 60e/QP 9")
    2009 Corvette Z06 HCI, Coilovers, 630whp | 1987 Iroc Sitting in the weeds | 2006 Silverado Z71 5.3 "HO" L33/60e, Baby cam'd at 240k and top end refresh, still going strong!
  10. The Following User Says Thank You to harner For This Post:
  11. #6
    Eh
    depends on the county, northampton/lehigh/montgomery county is full on inspection including emissions, other countys are like harner said. but if you stay below a certain mileage it is exempt anyway.
    2021 Durango R/T Tow-n-Go
  12. The Following User Says Thank You to SSlowBoat For This Post:
  13. #7
    LTX Regular
    Dec 2011
    Louisiana
    We have to have annual inspection here in La. in a group of local Parishes that have bad ozone. Some Parishes allow a two year inspection sticker.
    The State laws on smog inspection is pretty extensive including hooking the vehicle up through the data link and doing a full test to make sure all pollution controls work.
    No "lickem and stickem" because every smog test has to be on their computer on pollution controlled vehicles.
    I'll be glad when 2022 arrives because I'm gonna get an Antique plate and eliminate the annual inspection forever. It's just another pain in the ass to have to take care of.
    Especially because I have seven vehicles. Two are exempt, the '57 and now the '94. woop woop.
    My wife got one for her '94 when it reached 25 yrs. old.
    '94 Z28 Bone stock,4l60e
    '57 Chevy 3100 p/u LT1/T56
  14. #8
    Lancaster/Dauphin county area, I will need to figure out shops to take it to once I find a house.
  15. The Following User Says Thank You to shownomercy For This Post:
  16. #9
    Eh
    Technically you can have it inspected in any county, they just have to "inspect" it based on your resident counties requirements. I used to bring mine an hour away to a shop @popo8 recommended which was 2 counties over
  17. The Following User Says Thank You to SSlowBoat For This Post:
  18. #10
    That is interesting, did not know, thanks!
