Results 1 to 6 of 6
    LTX Regular
    May 2019
    DARREN BRANDON
    1983 jaguar xj6
    Default Cold air intake on my jag conversion
    Not a question, just a post showing what I ended up doing, maybe this should be in the project or engine swap section, if so please feel free to move....
    C32BCBCE-627B-4781-BEEF-CCC3AF5588FC.jpegE00E0A62-B4F4-4703-ACB7-704FF92720F8.jpegI went with the k&n filter and matching hose, Then. Used Fredís method of using a fernco pipe coupler to attach throttle body to maf.
    I kept seeing pictures of other jag swaps where the filter sits totally in front of the rail on top of the radiator upper support, but when I tried that, I couldnít close the hood, so I had to cut out a section and shift entire thing back about 1.5 inches and it is perfect. If by chance hot air is still getting in there itís massively outweighed by the amount of cold, so shouldíve good, guess I really need to run a scan and see what intake air temps are now!!! Should be a lot different than before....19B24C82-EA79-410A-8D26-5ACDA969C81A.jpeg
  2. The Following 2 Users Say Thank You to Darrenmb For This Post:
  3. #2
    LTX Regular
    Dec 2011
    Louisiana
    Looks good. Like the Corvette trim too.
    '94 Z28 Bone stock,4l60e
    '57 Chevy 3100 p/u LT1/T56
  4. #3
    Eh
    that looks awesome and im sure it gets plenty of air when going down the road.
    2021 Durango R/T Tow-n-Go
  5. #4
    Asshole.
    Nov 2008
    1994 Trans Am
    PA, USA
    Not as much as a PVC CAI, but it should hang.
    Chris.
    1994 Trans Am
    Under the knife - who knows when it'll run (5.3 LM7/CPT 60e/QP 9")
    2009 Corvette Z06 HCI, Coilovers, 630whp | 1987 Iroc Sitting in the weeds | 2006 Silverado Z71 5.3 "HO" L33/60e, Baby cam'd at 240k and top end refresh, still going strong!
  6. The Following User Says Thank You to harner For This Post:
  7. #5
    Pr0jekt Turb0?
    Ryan
    1993 Camaro Z28
    Utica, NY + Jacksonville, FL
    One thing to note which may or may not happen, but there have been people that have reported surging while moving in the corvettes when they open up the front for airflow with this type of CAI intake setup. It may require some tuning. I haven't opened up my NACA anymore than stock. Something to keep in mind in case it does happen. Apparently it can mess with the MAF readings or something.
    -Ryan
    93 Z28 M28
    Mod List
  8. #6
    LTX Regular
    May 2019
    DARREN BRANDON
    1983 jaguar xj6
    Quote Originally Posted by Z28pr0jekt View Post
    No issues that I have noticed yet, drove it to beach last weekend, 90 minutes at 70-75 mph,
    But will keep this in kind if anything starts happening,
    Thanks
