Results 1 to 1 of 1
    Dec 2011
    Mark
    Altoona, PA
    Default Vortech V1 S Trim / Crane Fireball HI-6R
    Bought in a kit about 10 years ago. Been sitting in storage ever since. Head unit only. Was told it had roughly 5,000 miles on when I bought it. No way to verify. No impeller marks in housing. No shaft play. Clockwise rotation. $1300 shipped.
    Crane FireBall HI-6R Ignition with LT1 harness and timing retard dial.
    $200 Shipped.
    Some reason I cant add pictures. Ill upload as soon as I figure out what the issue is.
