Results 1 to 5 of 5
Thread: what next?
    Jul 2015
    Nathan
    1996 Camaro Z28
    North St Paul, MN
    Default what next?
    Hey all. So... I'm kind of scratching my head and wondering what direction I should go in next and I'm wondering what everyone else's experience and thoughts are. I've got all of the fun aftermarket bolt on go fast goodies, I'll list separately below. I've dipped into the 12's a few times in mindshaft weather conditions, but mostly been hovering around the low 13's for the last few years. The car is making most of its ET in the first couple hundred ft. I'm getting bored with the car. Is there anything I'm missing, and if not, what should I do next? I'm not sure I'm ready to dive in with heads and cam yet. I really want to be solid in the 12's and find some more MPH. On average, I'm running 13.20-13.30's at 100-101 mph. Keep in mind I want to keep the car somewhat streetable, but no where near a daily driver. Just wondering if there are any bolt-ons im missing or if there is something else simple. Will a dyno tune find much more? Will updating valve springs and adding high ratio rockers yield much? Any info or advice helps. Please don't reply with "did you do a search?".
    CAI
    LT's
    3" exaust
    3600 stall
    3.73 gears
    6al MSD
    Solomn mail order tune
    All of the usual deletes, Cat, EGR, Air pump
    I'm sure I'm forgetting something...
    Thanks in advance for your input.
    nitrous
    LTX Regular
    Sep 2011
    95 ta
    little falls mn
    Any weight reduction? I’d put nitrous on it too if you don’t want do do heads/cam.
    Adam Legatt 95 trans am, 355 LE ported 21* TFS heads SS4000, 9'' 11.18@ 121.5 mph
    Pr0jekt Turb0?
    Ryan
    1993 Camaro Z28
    Utica, NY + Jacksonville, FL
    Rims, tires, weight reductions, shocks, springs, torque arm, TB bypass, rockers & springs (I suggest doing rockers bolts while you're in there as I snapped one while driving one time), EWP
    -Ryan
    93 Z28 M28
    Mod List
    Eh
    what tire you running? weight reduction, nitrous
    2015 Camaro 2SS 1LE
    1995 Firebird Formula - Le2 H/C, SBE, CPT 4l60E, boost?
