Page 6 of 18 FirstFirst ... 234567891016 ... LastLast
Results 51 to 60 of 176
  1. #51
    I would have just left it be in its home.
  2. The Following User Says Thank You to shownomercy For This Post:
  3. #52
    cmon, gm put 3 bolts on each side, you mean i only need 1!!!!
    got it Tapped just now. bolt goes in to the depth required. ill get new gaskets later this week and as long as my back isnt still fubar ill get the front buttoned up then proceed to tear apart the rear suspension
  4. #53
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Glad to hear you got it.
  5. The Following User Says Thank You to Fastbird For This Post:
  6. #54
    progress on this car or any car for that matter has been slow due to life in general. this year has been crazy. we ended up getting back into mountain biking heavy and spent what little free time doing that, as i just didnt have any motivation to do anything so i wanted to do something active that the kids could be part of (and be a little more interested in).
    well, i ended up hurting L4-L5 in my back doing of all things, yard work, not riding HAH. Since i cant ride and have to take it easy for a bit, focus has moved back to the bird.
    spent some time tonight mocking up intake from used parts collected over the years (filter is actually from the fiesta intake kit), fixing wiring issues and being the ziptie king. Need to get some heater hose tomorrow, wire ewp, put y pipe on, and bring it outside to bleed coolant.
    if all goes right i hope to be roasting em in the driveway tomorrow, then pull it back in and start tearing the rear suspension/axle out.
  7. The Following User Says Thank You to SSlowBoat For This Post:
  8. #55
    #teamziptieftw
  9. The Following User Says Thank You to shownomercy For This Post:
  10. #56
    summit ewp still works, got that wired up to the air pump relay today. buttoned up cooling system and began bleed process. cut off og exhaust. i want to get it outside to finish bleeding and get it up to temp, also need to pull tune and revise.
    old gas smells lovely with open headers in a small garage
  11. The Following User Says Thank You to SSlowBoat For This Post:
  12. #57
    brought 3.42 trutrac rear over to osies to make the brake lines. installed arp studs.
    have whole rear axle and suspension unbolted, just gotta cut the sway bar end links and shes out
  13. The Following User Says Thank You to SSlowBoat For This Post:
  14. #58
    dewalt 18v impact said i dont have to cut the swaybar links. so the og 2.73 is out of the car. also installed the energy poly trans mount and the fleabay header y pipe, which surprisingly fit really good (ie better than the headers).
  15. The Following User Says Thank You to SSlowBoat For This Post:
  16. #59
    got the 3.42 truetrac rear back together. new flex lines, hardlines, fittings, wheel studs, and fresh fluid.
    will start installing tomorrow
    also removed the leaky power steering return from rack line. gotta wait till that comes in to start car again. and my original balancer has a ridiculous wobble so i need a new pulley assembly.
  17. The Following User Says Thank You to SSlowBoat For This Post:
  18. #60
    rear is in. have to button up panhard adjustment, torque arm adjustment, and possibly drop the lca's to the lowest hole on the relocation brackets. i did the hose mod to the stock rear springs and the lca appears just barely level, possibly pitched up.
    then decide if im doing abs delete/linelock in short term or just bleeding and letting er rip
  19. The Following User Says Thank You to SSlowBoat For This Post:
