Page 13 of 18 FirstFirst ... 391011121314151617 ... LastLast
Results 121 to 130 of 176
  1. #121
    My car has no crunchy rusty.
    And agreed on the BMR ball joints, that sucked when I did mine
  2. The Following User Says Thank You to shownomercy For This Post:
  3. #122
    ok, your car was taken care of. mine definitely was not lol
  4. #123
    shes back on the ground for now. need to bleed front brakes again, and fix a hellish idle split blm issue (drivers bank goes to 105 ltft at idle) but shes running.
    oh yeah, gotta hit lowes tomorrow for some cold air intake parts.
    https://youtube.com/shorts/75aLaEnAQEM?feature=share
  5. #124
    I think that IAC passage should be fixed in the Tpis but not 100% on that.
  6. The Following User Says Thank You to shownomercy For This Post:
  7. #125
    going thru the old thread i believe it is, i probably have something else going on. thinking i should pop the injectors and send em to get cleaned/flowed. one is probably sticking
  8. #126
    edit, it is modded on the back of the tb, but there was no oem style 1/8" bleed hole, so that will have to get adjusted.
    just with cylinder trim changes and maf changes i was able to get the blms 124-132 so thats atleast a closer range.
  9. #127
  10. The Following 3 Users Say Thank You to SSlowBoat For This Post:
  11. #128
    Sep 2015
    Brandon++S
    1997 camaro z28
    Alabama
    Nice!!
  12. The Following User Says Thank You to Brandon++S For This Post:
  13. #129
    shes been pissing me off this week. between the brakes not wanting to have a consistent feel, to the tune being out of whack drastically, to finding out that they were NOT 32lb injectors (actually 37lb WTF) , its been a long week. im sure my neighborhood hates me, after driving up and down the road 6 times today to datalog.
  14. The Following User Says Thank You to SSlowBoat For This Post:
  15. #130
    so i did a thing today.......
    found a local wolfe chromoly bolt in 6 point double swing out rollbar for a good price (considering wolfe no longer exists) new in box. made the deal, just opened it up, its all there never installed. saturday i plan on getting this in that way my fiance can calm down 20210526_200832.jpg
  16. The Following 2 Users Say Thank You to SSlowBoat For This Post:
