Page 4 of 18 FirstFirst 1234567814 ... LastLast
Results 31 to 40 of 176
  1. #31
    Quote Originally Posted by Brandon++S View Post
    Do you use any kind of washer on the bolts?
    if i have clearance. if i dont, i dont. arp comes with washers. the bolts that come with the headers dont have washers.
  2. #32
    cluster***k today. got some time after taking my son to the doc to work on the bird. passenger side header was all mocked up, started mocking up drivers side, and ran into a bunch of issues.
    I didnt plan on changing motor mounts until winter when i put in my le2 motor. Welp drivers side was hitting motor mount bracket. ok clearanced bracket easily. put steering shaft in, hit both center primaries....shit. no one local had a new rubber one in stock, but since we are ltjuan hoarders, i had a drivers side poly already in the bracket.
    it still hit, so proceed to clearance. I may have went a little far with the hammer, but roadkill proved you dont lose much with dented primaries. now it fits, clears, etc. got the gasket in and drivers side header is buttoned up.
    passenger side will be completed after motor mount, then ltcc and fire it off.
    I blame @Catmaigne for jinxing me on the header hitting the steering shaft. he stopped by to trade torque arms from his firehawk, and he mentioned i may run into it with these headers...dick!!!
  3. The Following User Says Thank You to SSlowBoat For This Post:
  4. #33
    Steve's Spohn's first version of a torque arm. With anything other than stock power/torque, the single slider tube at the front (inside the bellows) will start to bend. He repaired mine by inserting a solid steel bar tight inside the hollow tube. When we did the stroker, he convinced me to do a complete replacement with a newer design.
  5. The Following User Says Thank You to Injuneer For This Post:
  6. #34
    just stock engine for now. it will be 9" in winter as well. lotta used parts that were free or cheap for the time being, they will be slowly transferred to the wifes 84 as i grow up lol
  7. #35
    got the passengers side motor mount in and done, the headers buttoned up, accessory bracket back on, now to fix the wiring and install ltcc
  8. #36
    for anyone wondering, the speed daddy/dna ebay stainless headers actually come with decent bolts, and i used the supplied bolts on the end holes, used the arps with washers in the other 4 positions on each side. arp's with washers would not work on the ends. the supplied bolts are 10mm head and 1" long, they work well.
  9. #37
    So much talking amd very little pictures... Im a simple man, damn it! I want to see!!!
  10. #38
    was busy working on osies car. trying to go to the track with it next weekend.
  11. The Following User Says Thank You to SSlowBoat For This Post:
  12. #39
    His ride is ready... just send it! Lol
    Headers look good. Dents don't look 2 bad.
  13. #40
    "Babe, what car are these o2 sensors from?"
    Her - "I dont know honey"
    "Hey Osie, what are these o2's from" @Ltconvert "like you care, put em in"
    thats how today went. Fiance forced me into the garage today, old guy came over and helped me put the plugs in, starter, new hd battery cables from innovative wiring, started laying out ltcc.
    Oh yea, repaired some sketchy wiring. Knock sensor was wired to performance shift button wire on pcm on the c connector, knock sensor is supposed to be on the d connector! wtf! MeKaNiC OwNeD my ass.
    gotta pick up a cheap oil change, install ltcc coils, put that damn fuel line relo in, and finish ltcc
  14. The Following User Says Thank You to SSlowBoat For This Post:
