Results 1 to 7 of 7
    May 2020
    Francis M Cwik Jr
    1996 Z28 SS
    Default Hello from Middle River, MD
    I just wanted to hello to everyone here on LTXTech!
    Aug 2013
    JB
    94 Camaro Z28
    Atoka,TN
    Hello
    May 2020
    Francis M Cwik Jr
    1996 Z28 SS
    I apologize! I guess that I should introduce myself. My name is Frank and I just joined. I am so glad to have found this place! It has already been a valuable source of information. I've owned my 96SS for 4 years and am just now starting the engine build.
    LTX Regular
    Sep 2015
    Brandon++S
    1997 camaro z28
    Alabama
    Welcome! Very good info on this site.
    Dec 2011
    Mark
    Altoona, PA
    Welcome, lots of info on this site and some very knowledgeable people that will gladly answer any questions you may have.
    Online
    Welcome ! ! !
    Let the engine build begin.....
    May 2020
    Francis M Cwik Jr
    1996 Z28 SS
    Thank you! The engine in your signature is very similar to my planned build. It will eventually be a 383, but avoid too much down time, I am doing the top end first and will enjoy it while a do a bottom end on a different block. I picked up a set of factory castings and, after some searching, they will be ported by Eric Bradby.
  8. The Following User Says Thank You to SLP390 For This Post:
