Results 1 to 4 of 4
Thread: Cam Install
    Apr 2020
    Jake D Janssen
    1995 Pontiac Firebird formula
    Default Cam Install
    It seems the dowel pin for my new cam is too short. It just protrudes far enough to come flush with the end of the cam gear and leaves nothing to drive the opti. The dowel is much shorter than stock. Any idea how I can remove this dowel and get a longer one pressed in? I also noticed there is a small amount of horizontal play (parallel with the crank axis) of 0.057" in the cam after the retainer is installed, is this normal?
    I put the stock cam back in and it only walks 0.015". Something doesn't seem right.
    Apr 2020
    Jake D Janssen
    Lunati said the end play was not an issue. I removed the old dowel and got a new one in.
    Sent from my GM1917 using Tapatalk
    Eh
    Quote Originally Posted by Jakegsxr11 View Post
    once you have the oil pump drive in along with driveshaft and oil pump, your end play will go down.
    the dowel swap thing is normal. i screwed up one time and cut down the dowel for a spline drive opti, then decided to go to a pin drive opti, had to break off and drill out the dowel and put a new one in.
    2015 Camaro 2SS 1LE
    1995 Firebird Formula - Le2 H/C, SBE, CPT 4l60E, boost?
    Mar 2013
    1995 Camaro Z28
    Columbus GA
    I had the same thing. Lunati sent my cam with the short dowel. After contacting them, they shipped me the correct size dowel, then i just took it to a local shop to replace and press in the new one.
