Results 21 to 30 of 120
04-27-2020, 03:04 PM #21'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
'57 Chevy 3100 p/u LT1/T56
Wife's '94 Z28 has been sold.
04-27-2020, 03:07 PM #22
04-27-2020, 03:36 PM #23LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
Really good work! It looks great
Sent from my SM-G955U using TapatalkSame as everybody else...350 small block, double hump heads, 3/4 cam
The Following User Says Thank You to Cathead For This Post:
04-28-2020, 05:07 AM #24
Thanks Cathead, I was beginning to wonder if I was just talking to myself. May be.
04-28-2020, 05:15 AM #25
the rest of the steering
I was able to get the steering column from the car that the engine/trans was in.
I modified it a bit to fit the original '57 steering wheel, that may change thought.
The column was too long to allow the correct angle on the steering shaft u-joints so I had to do an amputation.57 steering column amputation 007.JPG'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
04-28-2020, 05:16 AM #26'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
04-28-2020, 05:22 AM #27
Cut off about 6" from the column and shaft and cut new slots and grooves to retain the original bearing.
57 steering column amputation 011.JPG'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
04-28-2020, 05:22 AM #28'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
04-28-2020, 05:33 AM #29
Made a new base for the column
IMG_1739.JPG'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
04-28-2020, 05:43 AM #30
Trying to find all the steering photos, here's one of the telescoping steering shaft. It will have to travel with the straight axle over bumps. There was a problem in this photo with the u-joint phasing because they were two different brands. I had to order another u-joint.IMG_0034.JPG
