Results 11 to 20 of 120
04-27-2020, 10:18 AM #11'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
'57 Chevy 3100 p/u LT1/T56
Wife's '94 Z28 has been sold.
04-27-2020, 10:19 AM #12'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
04-27-2020, 10:24 AM #13
Cleaned up and painted the engine compartment, then started laying out the wiring harness and test fitting the steering column. I'm using the column from a '97 Camaro as well as the harness.
57 chevy 085.JPG'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
04-27-2020, 02:26 PM #14
This pic shows where the shifter needed to come up, which was under the bench seat and right where a structural rib is in the floor. At the time I started figuring I would have to go to bucket seats. The red X is where the shifter needed to be.57 chevy 013.JPG
04-27-2020, 02:32 PM #15
About this point I got side tracked on a boat project AND I bought the '97 SS. Poor truck got neglected again while I worked on the Camaro. I wound up getting the truck back in the shop and did more work on it. Then I had major valvetrain issues with the Camaro and did a top end rebuild on it. I finally decided to work on one project at a time until completed or I would never finish anything.
04-27-2020, 02:42 PM #16
Here's a spurt of work completed. Pulled the entire front suspension out. I rebuilt with new kingpins and bushings, new lowering springs and shackle bushings. Teardown;
newer teardown 57 pu 001.JPGnewer teardown 57 pu 004.JPG'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
04-27-2020, 02:45 PM #17'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
04-27-2020, 02:51 PM #18
I wanted to keep the straight axle suspension and alot of other things about the truck more retro versus completely modernizing it. But I did it in a way that will stop and steer much better.Disc brakes and power rack and pinion steering newer 57 pics front end work 025.JPGnewer 57 pics front end work 030.JPG
04-27-2020, 02:56 PM #19
04-27-2020, 03:01 PM #20
The plate brackets you se in the previous photo were made wrong by the company I bought them from. Somebody got his center to center measurements wrong. So I made my own out of 1/2" T6061 aluminum plate.SWAY BAR BRACKETS AND HOARDER SHOP 001.JPG
