Results 91 to 100 of 120
07-17-2020, 09:12 AM #91
Painted a spare set of valve covers, the ones on the engine are beat up bad. Gotta put a couple more coats of paint to get a gloss. I swear it's so hot the paint was drying in mid air before it hit the surface.IMG_3236.JPG
'57 Chevy 3100 p/u LT1/T56
Wife's '94 Z28 has been sold.
The Following User Says Thank You to JOATMON For This Post:
09-14-2020, 08:59 AM #92
Figured it was time to update this thread. Finally got the fuel system done after waiting 62 days for the tank to come in.
09-14-2020, 09:05 AM #93'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
09-14-2020, 09:09 AM #94
Got all the electrical done under the hood and started finding everything I needed to hook up under the dash. Sat the Camaro instrument cluster temporarily to use for test fire. Check out the low miles on this engine.
09-14-2020, 09:10 AM #95'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
09-14-2020, 09:16 AM #96
Ran all high pressure rubber lines with AN fittings including the vapor recovery line. Bought a new Camaro vapor recovery tank and mounted it under the p/u bed. got the
IMG_3259.JPGIMG_3260.JPGIMG_3263.JPG'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
09-14-2020, 09:24 AM #97
First test fire was a dud. After doing some testing I determined that all the injectors were stuck. Pulled the fuel rails and injectors and did a DIY flush on them. Fill the tube with B12 Chemtool, pump up some pressure and pusle 12 volts to the injector using a remote starter switch. Got alot of dried up fuel crud out of them. A few were so stuck I had to tap on them to break them loose. Put everything back together and got it running. Got a dead miss on #7 and a partial miss on #2. Spark checks good so I believe those two injectors are still cruddy. I'm gonna flush them again using higher pressure before I break down and buy a new set.
09-14-2020, 09:25 AM #98'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
09-14-2020, 09:28 AM #99
I'll post a video after I get it hitting on all 8 cylinders. Engine runs good, no smoke, no knocks and great oil pressure.
09-23-2020, 08:45 AM #100Xtreme Member
- 7,266
Supporting Membergreat success!!! nice trick on the injectors, ill keep that one for the archives of mildly sketchy diy for when i need it one day lol
