Results 1 to 9 of 9
    Apr 2020
    Dave Bryant
    1985 Jag xj6 with 1995 Caprice LT1
    Alaska
    Default LT4 knock module
    I have a 1995 LT1 engine that will be completely rebuilt and I plan to use an LT4 knock module in place of the stock unit. Is this a "plug-n-play" swap or does something also need to be done in tuning?
    Thanks
    Dave
    Plug-and-play. Unless you're going with full roller rockers, it may not be worth the inflated cost.
    Apr 2020
    Dave Bryant
    Alaska
    Yes, I'm going to use full roller rockers and you are right about the exorbitant cost!
    Dave
    i actually had a lt4 knock module fail on me once. it was weird. ended up using a stock lt1 module and got the tune right and it was good to go
    Apr 2020
    Dave Bryant
    Alaska
    I've heard that the extra noise from roller rockers could be tuned out, but my thought is that if you raise the threshold of the LT1 mod so that it ignores the rockers, wouldn't it maybe miss some of the ping if that was there? But then, maybe that's all the LT4 mod does anyway. I plan to send my PCM out for a tune, the donor car was wrecked in about 1996 and had sat somewhere until a couple of years ago when the PO thought he would do what I am doing. I have no idea what shape the PCM is in.
    Dave
    The knock module is a noise “filter”. For the LT4 it removes the specific noise signature of the roller rockers, plus whatever else it was filtering from the LT1. Interesting info - 1993 F-Body LT1 did not use a removable knock module.
  7. The Following User Says Thank You to Injuneer For This Post:
  8. #7
    Apr 2020
    Dave Bryant
    Alaska
    So the signatures of roller rockers and pre-ignition are different enough that an LT1 module could be tuned to ignore the rockers also and still retard the spark by identifying ping?
    Thanks for previous post, I appreciate it.
    Dave
  9. #8
    I'm not aware of any way to “tune” a knock module. The tuning is in the circuitry.
  10. #9
    Quote Originally Posted by daveb View Post
    Dave
    You can only "tune" it down by changing how much spark retard it pulls when it senses a knock event. Stock is 10 degrees, i usually set it for 3 degrees at certain rpm or map values to only really retard timing if it senses knock WOT.
