Results 1 to 10 of 11
Thread: Which 4L60e do I have?
04-21-2020, 08:18 PM #1LTX Member
- Apr 2020
- Dave Bryant
- 1985 Jag xj6 with 1995 Caprice LT1
- Alaska
- 15
I've read a couple of Darrenmb threads here on his Jag conversion and the interchange threads, but I don't find the answer to my exact question.
I have a 1995 LT1/4l60e from a 9c1 Caprice. I am looking ahead to when I will be ready to have the trans overhauled, but the info I've been able to find is not adding up. There is every indication and no reason to question that the engine/trans are a matched set and from the serial number on the trans it seems to be a 1995. However, the pump housing does not have PWM cast into it, but the electrical connector does have 13 pins, not 11. I got the original PCM and harness which I plan to use. I'm beginning to feel there might be an issue developing here. Here's a couple of pics.20200421_160354.jpg20200421_160450.jpg
Can anyone help me sort this out?
04-21-2020, 08:21 PM #2LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
The 4L60E in a 1995 is a stand alone year, meaning it will only work in a 1995.
PWM did not start until 1996.
Sent from my LM-V405 using TapatalkGail C. Cahall
04-21-2020, 08:22 PM #3LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
How did you confirm that all of it came from a 95?
04-21-2020, 08:24 PM #4LTX Member
- Apr 2020
- Dave Bryant
- Alaska
- 15
04-21-2020, 08:31 PM #5LTX Member
- Apr 2020
- Dave Bryant
- Alaska
- 15
The donor car was not available so the two main pieces of info I had was the serial# on the trans and the fact that the Opti Spark was vented. I believe somewhere I might have read that the harness connection on the trans was correct on the right side and the connector should have 13 pins for a '95. This is pretty slim pickin's, but it's all I've got.
What's your take?
Dave
The Following User Says Thank You to daveb For This Post:
04-21-2020, 09:02 PM #6LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Can you take a pic from both sides of the outside of the trans, including the bell and tail?
04-21-2020, 10:54 PM #7LTX Member
- Apr 2020
- Dave Bryant
- Alaska
- 15
Let me know if you need more.
04-22-2020, 11:22 AM #8LTX Member
- Apr 2020
- Dave Bryant
- Alaska
- 15
CPT, did these pics help at all?
04-22-2020, 11:25 AM #9LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
I sent you back an email.
04-23-2020, 03:45 AM #10LTX Member
- Apr 2020
- Dave Bryant
- Alaska
- 15
Here are the cam specs you asked about Gail. Do you need the stock specs to compare?
- Comp cams
Grind Number: 260XFIHR13
UPC: 036584116981
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,200-5,200
Intake Duration at 050-inch Lift: 210
Exhaust Duration at 050-inch Lift: 218
Advertised Duration: 260 int./270 exh.
Valve Lift with 1.6 Rocker Arm Ratio: 0.560 int./0.555 exhaust (0.526int./0.522exh. w/1.5 rockers)
Lobe Separation (degrees): 113
Computer-Controlled Compatible: Yes, Lifter Style: Hydraulic roller
Dave
