Results 1 to 5 of 5
Thread: GDScan question
04-17-2020, 09:34 AM #1Lurker
- Jun 2017
- Wes Brockway
- 1995 Z28 Camaro w/24X ignition
- Louisville, KY
- 1
GDScan question
Can GDScan be used to log wide band data? If so how is the WB O2 wired in? Through the AC Pressure wiring?
04-20-2020, 07:51 AM #2Xtreme Member
- 7,271
04-20-2020, 09:45 AM #3LTx Guru
@GaryDoug
If he doesn’t respond here, try CamaroZ28.com or FirebirdNation.com
04-20-2020, 10:29 AM #4LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
You can log into the ac pressure pin (D12 red/black wire) on the PCM however the data will show it as pressure and you would have to convert to the wideband reading somehow. I may be able to help with that conversion
Another long term option is to use the "D27" feature in the app Settings that logs the unused pin D27 voltage to the table as 0-5 vdc. Wire your wideband to pin D27 and select that option. It replaces the Baro pressure cell in the table (a static value that is not used for much anyway). The displayed reading is in the range of 0-5 vdc. You will have to interpret that somehow to your sensor.
The downside to this is that you would have to install another wire and terminal to pin D27 since it is likely unused for anything and has no wire.Last edited by GaryDoug; 04-20-2020 at 10:34 AM.
04-20-2020, 11:58 AM #5Xtreme Member
- 7,271
