Results 1 to 7 of 7
    Nov 2014
    LDM
    1994 Camaro Z28
    Default Stroker kit or new engine?
    Well with the stay at home orders here in IL I've been thinking about finally getting around to building the 383 stroker motor that I've been wanting to do for the last few years. I have an old engine that I need to tear down and check to see if the block is usable. But once that is done, then I have to make the decision.
    Are there any good LT1 stroker kits out there? I've done a few google searches but a lot of the stuff that comes up seems less the optimal. Ebay has some lower end kits that would probably be fine for a mild build but my plans are going to be on the higher end. I really want to build for a good 550-600 N/A with 200+ nitrous over the top for the track. I have no issue spending the money for this, I want parts that will hold up.
    The other option would be buying a new block and finishing it with the necessary parts. I've seen the Golen LT1 engines, anyone have experience with them all? Most of the info I can find is more than 5 years old, which I suppose it to be expected considering how few people are building the LT1 anymore. I would prefer to stay with the LT1 in this case, rather than stick an LS in there despite the easier time finding parts. Any info is appreciated, this isn't a hard timeline project or anything. More of a planning phase.
    Asshole.
    Nov 2008
    1994 Trans Am
    PA, USA
    @Karl Ellwein is the king of LT1 builders. Gail @ @American-Powerhouse can sell you a stroker kit.
    Chris.
    1994 Trans Am
    Under the knife - who knows when it'll run (5.3 LM7/CPT 60e/QP 9")
    2018 Camaro ZL1 CAI/Catback | 1987 Iroc Sitting in the weeds | 2006 Silverado Z71 5.3 "HO" L33/60e, Baby cam'd at 240k and top end refresh, still going strong!
  3. The Following User Says Thank You to harner For This Post:
  4. #3
    Asshole.
    Nov 2008
    1994 Trans Am
    PA, USA
    Chris.
    1994 Trans Am
  5. The Following User Says Thank You to harner For This Post:
  6. #4
    Nov 2014
    LDM
    1994 Camaro Z28
    Thanks for the links, I will give them a look.
  7. #5
    Nov 2013
    Corey
    94 Camaro z28
    new hampshire
    i have a golen 383 in my car, have probably 10,000 miles on it over the last 6 years with no issues. chad is a good guy and was more than helpful with any questions i had and i was even able to stop by the shop while my motor was being built (his shop is 5 minutes form my work). have also heard good things about karl but have no experience with him
  8. #6
    LTXTech Sponsor
    Jan 2013
    01 Chevy Corvette C5/05 Dodge Ram 1500
    United States
    Quote Originally Posted by LDM View Post
    Thank you for the recommendation @harner
    @LDM , if I can be of any assistance, please do not hesitate to contact me.
    Gail C. Cahall
    Founder
    American-Powerhouse, LLC
    www.american-powerhouse.com
  9. #7
    Eh
    Chad and Karl also have a relationship. karl sources alot of blocks pre machined from chad.
    What I can say for karl is, the motor he built for us has had the literal crap kicked out of it, thru bad tunes, more boost, overrev's etc and has not missed a beat. the amount of attention, care, and cleanliness of karl rivals nascar engine builders. I watched the man change gloves between touching each part, just to avoid any possibility of cross contamination. His ocd really helps as well. lol
    Either way you would be satisified. Also Gail is great and if you want to build it yourself, i would definitely go thru gail for a out of the box stroker setup
    2015 Camaro 2SS 1LE
    1989 Camaro RS - Le2 H/C, SBE, CPT 4l60E, boost?
