Results 1 to 10 of 10
    Sep 2016
    Brandon Reitz
    1995 Pontiac Trans Am
    Default Harness Question
    Anyone know what these harnesses are for? They are on the passenger side front near the alternator. Also, the 3rd picture, anyone have a diagram of this coolant hose? Mines rusted alittle.
    Quote Originally Posted by brarei200 View Post
    first pic ac compressor clutch, second inlet air temp, thats the steam line from back of engine.
  3. The Following User Says Thank You to SSlowBoat For This Post:
  4. #3
  5. The Following 2 Users Say Thank You to Injuneer For This Post:
  6. #4
    Sep 2016
    Brandon Reitz
    Anyone ever replace the steam pipe with AN fittings and braided lines with the motor still in the car?
    Thanks for the replies
  7. #5
    The factory steam pipe works fine. In the car im sure it could be done but would be a nightmare
  8. The Following User Says Thank You to SSlowBoat For This Post:
  9. #6
    It would be just as bad as installing the factory steam line IMO. But, if you are a purist, the AN fittings are not correct as factory is straight thread not taper.
  10. The Following User Says Thank You to shownomercy For This Post:
  11. #7
    Correct
    Youre "supposed" to take a 3/8" npt tap to them before installing the an fittings.
    I dont think installing a stock one was all that bad, i just got new bolts from hawks
  12. The Following User Says Thank You to SSlowBoat For This Post:
  13. #8
    I struggled with the double washer shens that GM dreamed up for that.
  14. The Following User Says Thank You to shownomercy For This Post:
  15. #9
    ac seals from the dorman help section fit just tight enough on the bolt to stay on
  16. The Following User Says Thank You to SSlowBoat For This Post:
  17. #10
    Dec 2011
    Louisiana
    I did a head job on mine in the car and had alot of trouble breaking loose the banjo bolts. I thought they were gonna snap. When I put it back together with new bolts and washer gaskets I was generous with never-seize. Also I'm pretty sure the threads are the same as (1/4" NPT) but they are straight not tapered. I came real close to converting it to pipe fittings and braided hose but then located new Ac Delco bolts and washer gaskets. Just general info FWIW
    Nolan
    '57 Chevy 3100 p/u LT1/T56
    Wife's '94 Z28 has been sold.
  18. The Following User Says Thank You to JOATMON For This Post:
