Thread: Harness Question
03-09-2020, 05:40 PM #1LTX Member
- Sep 2016
- Brandon Reitz
- 1995 Pontiac Trans Am
- 53
Harness Question
Anyone know what these harnesses are for? They are on the passenger side front near the alternator. Also, the 3rd picture, anyone have a diagram of this coolant hose? Mines rusted alittle.
03-10-2020, 10:20 AM #2Xtreme Member
- 7,266
03-10-2020, 09:22 PM #3LTx Guru
For future reference:
Courtesy of Shoebox
http://shbox.com/1/harness.htm
http://shbox.com/1/95-97_hoses.jpg
http://shbox.com/1/heater_hoses.jpgSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
03-11-2020, 08:23 AM #4LTX Member
- Sep 2016
- Brandon Reitz
- 53
Anyone ever replace the steam pipe with AN fittings and braided lines with the motor still in the car?
Thanks for the replies
03-13-2020, 08:46 AM #5Xtreme Member
- 7,266
03-18-2020, 08:58 AM #6
It would be just as bad as installing the factory steam line IMO. But, if you are a purist, the AN fittings are not correct as factory is straight thread not taper.
03-20-2020, 09:48 AM #7Xtreme Member
- 7,266
03-21-2020, 07:36 PM #8
I struggled with the double washer shens that GM dreamed up for that.
03-22-2020, 09:31 AM #9Xtreme Member
- 7,266
03-24-2020, 10:17 AM #10
I did a head job on mine in the car and had alot of trouble breaking loose the banjo bolts. I thought they were gonna snap. When I put it back together with new bolts and washer gaskets I was generous with never-seize. Also I'm pretty sure the threads are the same as (1/4" NPT) but they are straight not tapered. I came real close to converting it to pipe fittings and braided hose but then located new Ac Delco bolts and washer gaskets. Just general info FWIW
